【軟體名稱】:AIDA64 Extreme Edition 1.60.1351 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.6 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.60.1351 Beta 更新紀錄:
* anti-virus software support for DrWeb v6
* firewall software support for DrWeb v6
* identification of new Intel Xeon MP (aka Westmere-EX)
* RAID SMART support is now disabled by default
* Intel Processor Number detection for Core i7-995X
* Intel Processor Number detection for Xeon E7-xxxx
* detection of nVIDIA GeForce GT 520M video chip
* detection of nVIDIA NVS 4200M video chip
* GPU information for nVIDIA GeForce GT 555M (GF106M)
* GPU information for nVIDIA Quadro 1000M (GF108GLM)
* GPU information for nVIDIA Quadro 2000M (GF106GLM)
* GPU information for nVIDIA Quadro 3000M (GF104GLM)
* GPU information for nVIDIA Quadro 4000M (GF104GLM)
* GPU information for nVIDIA Quadro 5010M (GF110GLM)
* HD Audio codec information for nVIDIA GF116
* motherboard specific sensor info for Asus M4A77T
* motherboard specific sensor info for Asus M4A77T/USB3
* motherboard specific sensor info for Asus M4A77TD
* motherboard specific sensor info for Gigabyte G1.Guerrilla
AIDA64 Extreme Edition 1.60.1300 Final
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
