【軟體名稱】:AIDA64 Extreme Edition 1.60.1339 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.6 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.60.1339 Beta 更新紀錄:
* Intel Processor Number detection for Mobile Celeron 925
* detection of RDC M2012 video chip
* MCHBAR enabling on Dell OptiPlex 780
* sensor support for ITE IT8771F sensor chip
* motherboard specific sensor info for Asus E35M1-I Deluxe
* motherboard specific sensor info for Asus E35M1-M Series
* motherboard specific sensor info for Asus Sabertooth P67
* motherboard specific sensor info for Gigabyte H61M Series
* improved motherboard specific sensor info for ASRock boards
* fixed: Preferences / HW Monitoring / Alerting / settings saving
* fixed: GPU information for nVIDIA GeForce GTX 590 (GF110)
* fixed: motherboard specific sensor info for EVGA W555
* fixed: motherboard specific sensor info for Gigabyte 890GPA-UD3H
* fixed: motherboard specific sensor info for MSI MS-7350
AIDA64 Extreme Edition 1.60.1300 Final
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
