【軟體名稱】:AIDA64 Extreme Edition 1.60.1333 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.6 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.60.1333 Beta 更新紀錄:
* Display / GPGPU / support for nVIDIA CUDA 4.0
* Storage / Physical Drives / GPT support
* identification of Intel Celeron B8xx (aka Sandy Bridge)
* Intel Processor Number detection for Mobile Celeron B810, B847
* SMBus support for Intel Tolapai
* motherboard specific sensor info for MSI MS-7660
* motherboard specific sensor info for Sapphire Pure Black X58
* GPU information for nVIDIA GeForce GTS 450 (GF116)
* fixed: Display / GPGPU / CUDA core count detection on CC2.1 devices
* fixed: HD Audio codec information for Intel Ibex Peak
* fixed: motherboard database entries about Asus <-> Pegatron
* fixed: motherboard specific sensor info for Asus P5G41T-M Series
* fixed: motherboard specific sensor info for Asus P8P67-M Pro
AIDA64 Extreme Edition 1.60.1300 Final
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
