![AIDA64ExtremeEdition.png](http://i694.photobucket.com/albums/vv306/le2711/AIDA64ExtremeEdition.png)
【軟體名稱】:AIDA64 Extreme Edition/ Engineer 1.60.1321 Beta~免安裝
![61.gif](http://i571.photobucket.com/albums/ss156/le2760/61.gif)
【軟體語言】:多國語言
【軟體分類】:硬體工具
【軟體格式】:RAR
【檔案大小】:11.9 MB
【放置空間】:depositfiles/ mediafire
【解壓密碼】:no
![Introduction.png](http://i947.photobucket.com/albums/ad313/le2791/Introduction.png)
AIDA64 [原名EVEREST] 是一套由匈牙利Lavalys公司開發的一款優秀的軟硬體檢測工具並完全顯示 PC 系統所有資訊的五星級軟體,包括「Computer 電腦」、「Motherboard 主機板」、「Operating System 作業系統」、「Server 伺服器」、「Display 顯示器」、「Multimedia 多媒體」、「Storage 儲存」、「Network 網路」、「DirectX」、「Devices 裝置」、「Software 軟體」、「Security 安全性」、「Config 組態」、「Database 資料庫」及「Benchmark 效能測試」共 15 大項資訊,每一項都有詳細的資訊。
· 支援對各種處理器的偵測。
效能測試項目說明:
![Screenshots.png](http://i784.photobucket.com/albums/yy127/le2792/Screenshots.png)
![AIDA64ExtremeEdition.png](http://i984.photobucket.com/albums/ae330/le2774/AIDA64ExtremeEdition.png)
![Update.png](http://i1189.photobucket.com/albums/z437/le27941/Update.png)
AIDA64 Extreme Edition 1.60.1321 (Mar 10, 2011):
* identification of AMD Athlon II 1xxu (aka Sargas)
* Intel Processor Number detection for Core i3-330E, 2310E, 2310M
* Intel Processor Number detection for Core i5-520E, 2415M
* Intel Processor Number detection for Pentium P6300
* extended sensor support for Sony VAIO
* GPU sensor information for GMT G781 sensor chip
* GPU sensor information for SMSC EMC2101 sensor chip
* GPU sensor information for TI TMP431, TMP432 sensor chips
* motherboard specific sensor info for Asus P5G41T-M Series
* motherboard specific sensor info for Foxconn Dreadnought
* motherboard specific sensor info for Gigabyte G1.Assassin
* motherboard specific sensor info for Gigabyte H67/P67/PH67 B3 Series
* fixed: Intel Processor Number detection for Pentium P6200
* fixed: GPU clock measurement for AMD Radeon HD 6250/6310 (Wrestler)
* fixed: GPU temperature measurement on nVIDIA G92
![Download1.gif](http://i571.photobucket.com/albums/ss156/le2760/Download1.gif)
![Hp.png](http://i1202.photobucket.com/albums/bb380/le3900/Hp.png)
![Download.png](http://i1017.photobucket.com/albums/af297/le2793/Download.png)
