【軟體名稱】:AIDA64 Extreme Edition 1.60.1321 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.6 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.60.1321 Beta 更新紀錄:
* identification of AMD Athlon II 1xxu (aka Sargas)
* Intel Processor Number detection for Core i3-330E, 2310E, 2310M
* Intel Processor Number detection for Core i5-520E, 2415M
* Intel Processor Number detection for Pentium P6300
* extended sensor support for Sony VAIO
* GPU sensor information for GMT G781 sensor chip
* GPU sensor information for SMSC EMC2101 sensor chip
* GPU sensor information for TI TMP431, TMP432 sensor chips
* motherboard specific sensor info for Asus P5G41T-M Series
* motherboard specific sensor info for Foxconn Dreadnought
* motherboard specific sensor info for Gigabyte G1.Assassin
* motherboard specific sensor info for Gigabyte H67/P67/PH67 B3 Series
* fixed: Intel Processor Number detection for Pentium P6200
* fixed: GPU clock measurement for AMD Radeon HD 6250/6310 (Wrestler)
* fixed: GPU temperature measurement on nVIDIA G92
AIDA64 Extreme Edition 1.60.1300 Final
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
