【軟體名稱】:AIDA64 Extreme Edition 1.50.1255 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.5 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.50.1255 Beta 更新紀錄:
* improved hot-plug storage device support
improved RAID member enumeration for AMD SB7xx/8xx RAID controllers
improved RAID member enumeration for JMicron RAID controllers
* support for Intel Cougar Point PCH with B3 stepping
* sensor support for ITE IT8781F sensor chip
* sensor support for Dell SMI of Vostro 1710
* motherboard specific sensor info for Asus P8H67-M Series
* improved motherboard specific sensor info for ASRock boards
* fixed: Devices / Windows Devices / refresh issues
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
