【軟體名稱】:AIDA64 Extreme Edition 1.50.1251 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.5 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com/
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.50.1251 Beta 更新紀錄:
* Hardware Monitoring / new items: CPU1 DIMM, CPU2 DIMM voltage
* Intel Processor Number detection for Pentium E5800
* improved CPU clock measurement on AMD K10
* Display / GPU / Texture Mapping Units information
* GPU information for AMD Radeon HD 6450 (Caicos)
* GPU information for AMD Radeon HD 6470M (Seymour)
* GPU information for AMD Radeon HD 6570 (Turks)
* GPU information for AMD Radeon HD 6650M (Whistler)
* GPU information for AMD Radeon HD 6670 (Turks)
* GPU information for ATI FirePro 2460 (Cedar)
* GPU information for new nVIDIA GeForce GT 330 (GT216)
* GPU clock measurement for Intel Sandy Bridge IGP
* texel fillrate calculation for AMD R600+
* monitor information / improved vendor and model name detection
* HD Audio codec information for AMD Caicos, Seymour
* HD Audio codec information for AMD Turks, Whistler
* sensor support for Dell SMI of OptiPlex 980
* sensor support for ITE IT8772F sensor chip
* motherboard specific sensor info for Asus M4A88TD-M Series
* motherboard specific sensor info for Foxconn H67S
* improved exception handling on info pages
* fixed: CPU multiplier detection for AMD K14
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
