【軟體名稱】:AIDA64 Extreme Edition 1.50.1241 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.5 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com/
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.50.1241 Beta 更新紀錄:
* detection of AMD Catalyst 11.1 driver
* detection of AMD Catalyst 11.1a driver
* extended reference OpenGL Extensions list (for AMD Cayman)
* improved hot-plug storage device support
* improved disk temperature measurement for Intel ICH/PCH RAID controllers
* improved disk temperature measurement for JMicron RAID controllers
* chipset information for Intel ICH8 Series (with Pineview)
* chipset information for Intel ICH9 Series (with Pineview)
* GPU I2C support for AMD Radeon HD 6xxx
* HD Audio codec information for nVIDIA GF114
* motherboard specific sensor info for Asus P8P67 WS Revolution
* motherboard specific sensor info for MSI MS-7672
* fixed: Motherboard / Memory / pagefile usage display issues
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
