【軟體名稱】:AIDA64 Extreme Edition 1.50.1224 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.5 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com/
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.50.1224 Beta 更新紀錄:
* Hardware Monitoring / new items: VCCIO, VCCSA voltages
* Koolance sensor support via shared memory
* motherboard specific sensor info for Asus P8P67 Series
* improved motherboard specific sensor info for ASRock boards
* GPU information for nVIDIA GeForce GTX 560 Ti (GF114)
* CHiL CHL8266 GPU sensor support is limited to GF100+ now
* fixed: sensor support for Nuvoton NCT677xF sensor chips
* fixed: motherboard specific sensor info for Asus Sabertooth X58
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
