【軟體名稱】:AIDA64 Extreme Edition 1.50.1219 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.5 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com/
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.50.1219 Beta 更新紀錄:
* Preferences / HW Monitoring / new option: disk temp poll freq
* HW Monitoring / serial number indicator for similar drive models
* improved RAID member enumeration for JMicron RAID controllers
* SPD memory information for ECS 7AT-3L motherboard
* sensor support for Dell SMI of Vostro V130
* improved fan RPM measurement on Asus P7H55, P7P55 Series
* motherboard specific sensor info for Gigabyte H67A, H67M Series
* motherboard specific sensor info for Gigabyte P67A, PH67 Series
* fixed: slow startup on nVIDIA RAID controllers
* fixed: GPU temperature measurement on Zotac 8800GT
* fixed: motherboard specific sensor info for ASRock 890FX Deluxe3
* fixed: motherboard specific sensor info for ASRock 890FX Deluxe4
* fixed: motherboard specific sensor info for Intel DB65, DH61, DH67, DP67, DQ67 Series
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
