【軟體名稱】:AIDA64 Extreme Edition 1.50.1212 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.5 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com/
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.50.1212 Beta 更新紀錄:
* improved identification of Apple Mac systems
* improved support for mobile Intel Sandy Bridge processors
* Storage / SMART / improved support for Samsung SSDs
* sensor support for Dell SMI of Studio 1569
* improved sensor support for LM63-compatible chips
* motherboard specific sensor info for Asus P7H55-M
* motherboard specific sensor info for Asus P7H55-M LE
* motherboard specific sensor info for Asus P7H55-M LX
* motherboard specific sensor info for Asus P7H55-M Plus
* motherboard specific sensor info for Asus P7H55-M/USB3
* fixed: connection speed detection for USB 3.0 devices
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
