【軟體名稱】:AIDA64 Extreme Edition 1.20.1176 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.4 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com/
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.20.1176 Beta 更新紀錄:
* support for Logitech G13/G15/G19 keyboards with v7 software
* preliminary support for Intel Cedarview processor
* improved support for Intel Sandy Bridge processors
* Intel Processor Number detection for Core i5 480M
* GPU information for nVIDIA GeForce GT 540M (GF108M)
* GPU information for nVIDIA GeForce GTX 570 (GF110)
* preliminary GPU information for AMD Radeon HD 69xx Series (Antilles, Cayman)
* improved RAID member enumeration for AMD SB7xx/8xx RAID controllers
* improved RAID member enumeration for JMicron RAID controllers
* improved RAID member enumeration for nVIDIA RAID controllers
* sensor support for Fintek F71858AD sensor chip
* sensor support for ITE IT8728F sensor chip
* improved fan RPM measurement on Asus M4N82 Deluxe, M4N98TD Evo
* motherboard specific sensor info for MSI MS-7635, MS-7681
* improved motherboard specific sensor info for ASRock boards
* fixed: ASPI devices enumeration under Windows Vista+
* fixed: motherboard specific sensor info for MSI MS-7666
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
