【軟體名稱】:AIDA64 Extreme Edition 1.20.1165 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:11.3 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com/
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.20.1165 Beta 更新紀錄:
* improved support for Intel Sandy Bridge processors
* Intel Processor Number detection for Core i5 2300
* Intel Processor Number detection for Pentium G620, G620T, G840, G850, P6100
* Hardware Monitoring / new item: GPU MC utilization
* Hardware Monitoring / new item: GPU VE utilization
* Hardware Monitoring / new item: GPU +12V voltage
* Hardware Monitoring / new item: GPU VRM power
* extended sensor support for Sony VAIO
* improved negative temperature support
* GPU information for ATI Mobility Radeon HD 6370 (Robson)
* GPU sensor information for CHiL CHL8266 voltage regulator chip
* GPU fan duty cycle detection for nVIDIA GF10x, GF11x
* fixed: fan RPM measurement on W83667HG, W83677HG sensor chips
* fixed: NB & SB temperature measurement on Asus Rampage III Series
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
