【檔案名稱】:Active@ ISO Burner v2.5.0-專門映像檔燒錄工具
【檔案大小】:3.37 MB(解壓後)
【檔案格式】:EXE
【作業系統】:Windows All
【官方網站】:http://www.ntfs.com/iso-burning.htm
【語言種類】:正體中文
【正體中文編譯】:丹楓(虫二電氣診所)
【檔案簡介】:
您是否想在任何一部電腦上需要燒錄映像檔時可馬上燒錄,而不需再安裝任何燒錄軟體呢?倘若是的話,您可以試試 Active@ ISO Burner。
Active@ ISO Burner 可能是在 CD 和 DVD 上燒錄 ISO 映像檔的最簡單工具。Active@ ISO Burner 滿足初學者和專業使用者的一致好評。
本程式可以使用 CD-R、DVD-R、DVD + R、CD-RW、DVD-RW、DVD + RW 和藍光光碟,這意味著它幾乎支援任何格式光碟,並可在其上燒錄 ISO 映像檔。
其支援多種燒錄模式,軌段一次寫錄、區段一次寫錄、光碟一次寫錄 PQ 和光碟一次寫錄 raw P-W,也有專門選項可選擇燒錄速度和燒錄的副本數。
完成所有的設定後,您所要做的是按下 [燒錄] 按鈕,將開始在光碟上進行燒錄 ISO 映像檔的過程。
「設定」功能表提供您設定可重複燒錄光碟的抹除方法和燒錄後的選項。
結論相當簡單,Active@ ISO Burner 被證明是即時燒錄 ISO 映像檔最有效的方法之一,無須浪費太多時間在一些不必要或太複雜的設定上。
This tool is probably one of the easiest ways of burning ISO images on CDs and DVDs, as the whole procedure can be carried out in minutes from a simple and clean interface. Thanks to its simple approach, Active@ ISO Burner addresses beginners and professional users alike.
The application can work with CD-R, DVD-R, DVD+R, CD-RW, DVD-RW, DVD+RW and even Blu-ray discs which means it can burn ISO images on almost any support currently in existence.
There are multiple burning modes available, Track-At-One, Session-At-Once, Disc-At-Once PQ and Disc-At-Once raw P-W, but also dedicated options to choose the burning speed and the number of copies to be made.
When all the configurations are complete, usually after a minute or two, all yo have to do is hit the big 'Burn' button and the process of copying ISO images onto the loaded disc will begin.
The 'Settings' menu offers you the possibility to configure the erase method for rewritable discs and also choose some burn as well as after-burn options.
The conclusion is quite simple, Active@ ISO Burner proves to be one of the most efficient methods of burning ISO images on the fly, without wasting too much time with unnecessary or too complex configurations.
免責聲明:
本人所提供的中文化軟體僅供各位下載測試使用而不提供軟體相關使用教學說明。
1.倘若軟體屬於共享試用軟體,下載軟體試用後請在「產品試用期」到期時移除。本人不對所提供的共享試用軟體負任何法律責任。
2.軟體下載使用前請自行考慮清楚,本人不對因使用軟體而導致電腦產生的任何問題負責,欲使用請自行承擔風險。
主檔上傳 VirusTotal 掃瞄結果(少數防毒軟體報毒乃加殼所致;喜歡、敢用者請下載使用,不喜歡、不敢用者沒人強迫您們使用請勿下載)如下:
http://imurl.net/fa4iAY
若有新版本發行,請在論壇發短訊(短消息)或部落格留言告知以便儘速翻譯更新成正體中文化版本。
載點:
解壓密碼:Danfong@Hsieh
【檔案大小】:3.37 MB(解壓後)
【檔案格式】:EXE
【作業系統】:Windows All
【語言種類】:正體中文
【正體中文編譯】:丹楓(虫二電氣診所)
【檔案簡介】:
免責聲明:
載點:
解壓密碼:Danfong@Hsieh
