[燒5到碟]用Alcohol 120%同ImgBurn
iceman87319
普通會員
部電腦唔知做咩事
都會每次燒D野 2-3分鍾內 出現error
之後問我report唔report
可以點解決
AppName: _alcohol.exe AppVer: 1.9.6.5429 ModName: _alcohol.exe
ModVer: 1.9.6.5429 Offset: 0009e3a9
########################### System Information ###########################
Windows XP Professional 5.1 Service Pack 3 (Build 2600)
Processor info: AMD Athlon(tm) 64 Processor 3500+ (2209MHz)
Memory Available to Windows: 2,097,151 KB
############################ Program Information ###########################
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\_Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: Alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2007 Alcohol Soft Development Team
Version: 1.9.6 ( Build 5429 )
Date: 2007/07/02
Hash: 6f7f9396465f36d90421efc8c99fe076
Hash(1): d1a71e26c6484f6e3c73f78e7f2a9d4e64a3b47b09eff52c92aaaee6e7926c1f
Hash(2): 754c9687fdb69cb9f833c79770700c53e7fff6f92fcc02f33be965965952cd80
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Company Name: Alcohol Soft Co., Ltd.
Description: Alcohol virtual device control library
Original: alcoholx.dll
Product: Alcohol
Copyright: Copyright (C) 2000-2006
Version: 4.10.0 ( Build 0 )
Date: 2007/06/04
Hash: 854741219568150eb400c9b7ca1f5926
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Copyright: Copyright(C) 2002-2006 Alcohol Soft Development Team
Version: 2.5.2 ( Build 604 )
Date: 2007/07/02
Hash: 00ff3f64892b915ad0a017eacb0f61df
########################### User Information ###########################
Licensed to: GEGTER
Registered User ID: 2007
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 256
Examine the accuracy of data read from physical device: Yes
Enable Enhanced Weak Sector Scanner during dumping: No
Overburn disc(s): No
Turn off "Auto-Select best write speed" function if possible: No
Fill memory buffer before recording discs: Yes
Book Type DVD+R/DVD+RW disc as DVD-ROM while burning: No
Ignore Media Type: No
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language: Traditional Chinese
############################ Device(s) List ############################
(E:) PIONEER DVD-RW DVR-111 (atapi, Port 0, Bus 0, Target 0, Lun 0)
(G:) TX4284S YHB563D (aj4eywip, Port 5, Bus 0, Target 0, Lun 0)
(H:) TX4284S YHB563D (aj4eywip, Port 5, Bus 0, Target 1, Lun 0)
(I:) TX4284S YHB563D (aj4eywip, Port 5, Bus 0, Target 2, Lun 0)
##################### Installed Device Drivers List #####################
ACPI.sys ADIHdAud.sys AEAudio.sys afd.sys agpCPQ.sys
agpkx.sys aj4eywip.SYS alim1541.sys amdagp.sys amdagp8p.sys
AmdK8.sys ASACPI.sys atapi.sys atisgkaf.sys ATMFD.DLL
audstub.sys BATTC.SYS bb-run.sys BeatTrojanHelperOne.sys Beep.SYS
BOOTVID.dll Cdfs.SYS cdrom.sys CLASSPNP.SYS compbatt.sys
disk.sys dmio.sys dmload.sys DontGo.sys drmk.sys
Dxapi.sys dxg.sys dxgthk.sys eamon.sys eaps2kbd..sys
easdrv.sys eawdmfd.sys epfwtdir.sys Fastfat.SYS fdc.sys
Fips.SYS flpydisk.sys fltMgr.sys Fs_Rec.SYS fsvga.sys
ftdisk.sys gagp30kx.sys hal.dll HDAudBus.sys HIDCLASS.SYS
HIDPARSE.SYS hidusb.sys HTTP.sys i2omgmt.sys i8042prt.sys
imapi.sys ipnat.sys ipsec.sys isapnp.sys kbdclass.sys
KDCOM.DLL kmixer.sys ks.sys KSecDD.sys mnmdd.SYS
mouclass.sys mouhid..sys MountMgr.sys mrxdav.sys mrxsmb.sys
Msfs.SYS msgpc.sys mssmbios.sys Mup.sys nbf.sys
NDIS.sys ndistapi.sys ndisuio.sys ndiswan.sys NDProxy.SYS
netbios.sys netbt.sys Npfs.SYS ntdll.dll Ntfs.sys
NTOSBOOT.EXE Null.SYS nv_agp.sys nv4_disp.dll nv4_mini.sys
NVENETFD.sys nvgts.sys nvnetbus.sys NVNRM.SYS OVCAM2.sys
OVCD.sys OVCODEK2.sys parport.sys PartMgr.sys ParVdm.SYS
pci.sys pciide.sys PCIIDEX.SYS perc2hib.sys portcls.sys
psched.sys ptilink.sys rasacd.sys rasl2tp.sys raspppoe.sys
raspptp.sys raspti.sys rdbss.sys RDPCDD.sys rdpdr.sys
redbook.sys SCSIPORT.SYS Senfilt.sys serenum.sys serial.sys
SiRemFil.sys sisagp.sys SiWinAcc.sys sptd.sys sr.sys
srv.sys STREAM.SYS swenum.sys sysaudio.sys tcpip.sys
TDI.SYS termdd.sys tmagp.sys uagp35.sys Udfs.SYS
ULiAGP.sys update.sys USBD.SYS usbehci.sys usbhub.sys
usbohci..sys USBPORT.SYS vga.sys viaagp.sys viaagp1.sys
VIDEOPRT.SYS VolSnap.sys wanarp.sys watchdog.sys wdmaud.sys
win32k.sys WMILIB.SYS ws2ifsl.sys xfilt.sys
################## Detailed Information of Device(s) ##################
(E:) PIONEER DVD-RW DVR-111(0:0) detail information.
Vendor Identification: PIONEER
Product Identification: DVD-RW DVR-111
Production Revision Level: 1.19
Support recording method: DAO, RAW DAO(96), TAO, DVD DAO
BURN-Free Technology: BURN-Proof
Auto-Select best write speed: Not Supported
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: Yes/Yes
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: No
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: No
R-W De-interleaved and Corrected: No
C2 Pointers Support: No
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
###################### Source Disc/Image Information ######################
類型: 標準 ISO 映像檔案
路徑: D:\MSDN_Windows 7_x86+x64_2in1_9合1_台灣中文旗艦自動啟動版\
名稱: MSDN_Windows 7_x86+x64_2in1_9合1_台灣中文旗艦自動啟動版.iso
大小: 4154.72 MB
區段: 1
碟軌: 1
區段 01:
碟軌 01: DVD, 長度: 2127216(4.06 GB), 位址: 000000
####################### Dumping/Recording Progress Log #######################
********* Time stamp of this log file: 2009/12/11 上午 11:26:55 *********
11:26:55 CPU 資訊: AMD Athlon(tm) 64 Processor 3500+ (2209MHz)
11:26:55 Windows可用記憶體:2,097,151 KB
11:26:55 緩衝記憶體大小: 256 MB
11:26:55 映像檔載入中: D:\MSDN_Windows 7_x86+x64_2in1_9合1_台灣中文旗艦自動啟動版\MSDN_Windows 7_x86+x64_2in1_9合1_台灣中文旗艦自動啟動版.iso
11:26:55 DVD 來源檔案資訊: 區段: 1, 碟軌: 1, 長度: 4.06 GB / 472:42:66
11:27:01 (E:) PIONEER DVD-RW DVR-111(0:0): 燒錄模式/速度
11:27:01 燒錄中 - DVD DAO - 4.0X (5540 KB/Sec)
(E:) PIONEER DVD-RW DVR-111(0:0) - Media format: DVD-R
11:27:49 (E:) PIONEER DVD-RW DVR-111(0:0) - [Write ERROR] LBA: 784, Length: 16
S:KEY - 04/44/00 - "Internal Target Failure"
11:27:49 (E:) PIONEER DVD-RW DVR-111(0:0): 燒錄失敗!
11:27:49 錯誤訊息: [04/44/00] - Internal Target Failure
11:27:49 映像檔載入中止!
11:27:51 燒錄過程之中有錯誤發生!
請檢查記錄檔並回報任何訊息給技術支援服務。
ken21
永不上線
如果系統有節能軟體建議先關掉或移除
並到官網下載新韌體
