我的硬碟是WD 3200YS的 剛用半年 Hard Disk Sentinel 顯示
Failure Predicted - Attribute: 191 Count of problems caused by mechanical shock. Acceleration (for example falling) can cause mechanical shock.
Failure Predicted - Attribute: 253 Vendor-specific. The function and value of this attribute are determined by the manufacturer.
Failure Predicted - Attribute: 255 Vendor-specific. The function and value of this attribute are determined by the manufacturer.
Failure Predicted - Attribute: 239 Vendor-specific. The function and value of this attribute are determined by the manufacturer.
Replace hard disk immediately.
It is recommended to backup often to prevent data loss.
