各位先進好:
主機板:SABERTOOTH X79 CPU:i7-4940K 顯示卡:ASUS STRIX GTX˙1050TI 04G GAMMING 記憶體:ddr3 1866 8G X 4 螢幕:DELL U2515H 作業系統:WIN7
使用電腦時,經常發生螢幕顯示"enter power saving mode",然後螢幕關閉、鍵盤和滑鼠鎖住,無法喚醒電腦(電腦應該沒有當機),只好強迫關掉電源重新開機。
試過網路上教導的各種方法都沒有效果,例如:
https://www.dell.com/community/Desk...power-save-mode-problem-Pls-Help/td-p/4157152
也有人建議顯示卡驅動程式更至最新,可是當我這麼做時,卻又頻繁出現BCCODE 116的錯誤(更糟糕,導致電腦真的當機),只好回復到舊的驅動程式,而繼續出現"enter power saving mode"。
後來我又購買另外一個螢幕SAMSUNG U28D590D ,以雙螢幕方式使用,原以為以U28D590D為主螢幕,DELL即使"enter power saving mode",也不至於"螢幕關閉、鍵盤和滑鼠鎖住,無法喚醒電腦",但是很不幸的,情況依然發生,並無法解決問題。
請問各位先進,您們有解決這樣問題的經驗嗎?
謝謝您們,也祝福您們。
- Click Start button, click Control Panel, click System and Security, and then click Power Options.
- On the Select a power plan page, click Change plan settings for the plan that you want to change.
- On the Change settings for the plan page, click Change advanced power settings.
- On the Advance settings tab, expand Sleep, expand Allow Hybrid Sleep, and choose OFF.
- On the Advanced settings tab, expand Sleep, expand Allow wake timers, choose Disable for both when your computer is running on battery and when it's plugged in, and then click OK.
- On the Advanced settings tab, expand USB settings, under USB settings expand USB selective suspend settings, choose Disable.
- Click Apply and then OK to save the changes.
謝謝您們,也祝福您們。
